C284e Inverted scanner in duplex
  • Sniwy
    • Jun 2014
    • 11
    I got a problem with a C284e, when I scan in duplex, the rear side comes inverted, how can I solve this?
    Thanks in advance
  • emujo
    • Jun 2009
    • 3009
    Re: C284e Inverted scanner in duplex
    Check your "binding position" under application/original settings. Should be "auto" but you may have to change the settings to accommodate the way you are positioning paper in the feeder. Emujo
    • Sniwy
      • Jun 2014
      • 11
      Thanks for the answer. That way you said worked
        • 23010
        If I remember correctly it's described as SEF: short edge feed (at the leading edge of the original) or LEF: long edge feed (at the leading edge of the original). =^..^=
