BizHub C353 jamming
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    BizHub C353 jamming
    10:47:21
    Subject: BizHub C353 jamming
    IP: Logged
    Message:
    Intermittent jamming and folding paper at transfer
    section on right side. Jam code is 3001. I went
    there and ran 200+ pages and couldn't get it to jam.
    Of course 2 days later it is doing it again.
    Customer sent me attached pictures
    Any help appreciated.
    TIA
  • paulrid
    • Nov 2011
    • 206
    Re: BizHub C353 jamming
    I've seen this a few times and I can see from your photos what I would say it is. Change the secondary transfer roller as the black sleeve is missing from the right hand side.
    Paul.
    • copyman
      Owner / Technician
      • Sep 2005
      • 4718
      Without sounding to stupid what is the secondary transfer roller? I know the transfer roller on the side door that easily comes out by lifting 2 levers.
      Looked in the parts manual and didn't see a "secondary" transfer roller, unless I missed it.
      Thanks again for the help
      • paulrid
        • Nov 2011
        • 206
        That's the one with the two levers in the right hand side door, perhaps I've not got the name right.
        Paul.
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Paul.
          Nothing wrong with what you called it, it IS the second transfer roller - the one thats in the door. The first transfer rollers are the ones in the transfer belt unit.
          • stevena86
            • Oct 2012
            • 130
            A little simpler, flip the paper. I've found that moisture in the paper will cause it to curl when it hits the registration roller, not enter the fuser and fold and jam.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4718
              Thanks everyone for the replies. I will try what was suggested.
              As for what the trans roller is called. The service & parts manuals call it "transfer roller unit". This is what threw me off.
              • Synaux
                • Mar 2012
                • 1224
                Its normally called the secondary roller only in the Theory of Operation manuals.
                • Hansoon
                  • Sep 2007
                  • 3389
                  I like "2nd Transfer Roller" cause its the second transfer process.
                  Hans
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4718
                    Good stuff. Learn something new everyday. I knew I should've read those "Theory of Operation" manuals
                    • habik
                      • 2013
                      Yup they are fantastic
                      Firmwares HERE
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4718
                        Thanks everyone. Problem solved. Paulrid had it right. The black sleeve was missing from rear side of trans roller. I love when something is that simple. Thanks again
