fk 502 fax installation question
  • brent
    • Nov 2008
    • 1214
    I am putting a fk 502 kit into an existing machine in the field. problem is. I wanted to get an installation manual
    on my konica minolta it shows this kit with the mk 720 but its for a c652 c452 is this close to the same instructions?
    I would hate to get into it and have this not be the right manual. thoughts?
    brent
  • emujo
    • Jun 2009
    • 3009
    Re: fk 502 fax installation question
    The instructions are similar to the C650, MK720 goes in, FK 502 slides in from the side, but it goes in the opposite slot the 650 calls for. Then, service mode to install the fax, initialize it, and test. You may want to have the latest firmware version for the C652 if the fax was ever installed in a different MFP. Emujo
    After re-reading your post, I'm not sure what model of MFP you are putting the FK-502 in. I is used in several models, the mount kit is different from family to family though.
    • brent
      • Nov 2008
      • 1214
      I am installing it into a bizhub c360
      • emujo
        • Jun 2009
        • 3009
        C280 uses the MK720/Fk502..You should be fine, but have the firmware handy anyway.. Emujo
          • 23010
          I'll see if I can scan those installation instructions tomorrow AM. =^..^=
          Edit: I found a PDF.
          • brent
            • Nov 2008
            • 1214
            thanks so much black cat. I j ust noticed your post with the instructions. I had the ones for the higher speed machine. this exactly what I needed
            you are too good to me
            brent
              • 23010
              I'm glad to help. =^..^=
