Bizhub C280 Wont Copy or print NO ERROR CODE ???????
  • QUALITY IMAGING
    • Mar 2007
    • 20
    [Misc] Bizhub C280 Wont Copy or print NO ERROR CODE ???????
    C280 Wont copy or print, not reports or anything. It all goes into the Que and says Stop Print. Formatted the Hard Drive. Same problem. No error codes. Get Blue start light and the red light on side. Please Help.
  • emujo
    • Jun 2009
    • 3009
    Re: Bizhub C280 Wont Copy or print NO ERROR CODE ???????
    One or more of your consumables has reached it's life end. Either replace the needed items, or install the PPLM mod as this will allow the MFP to run past the stops. Emujo
    • QUALITY IMAGING
      • Mar 2007
      • 20
      I checked the consumables and nothing is maxed out. Could something still be at lifes end?
      • CompyTech
        Super Tech
        • Feb 2011
        • 706
        Had a similar problem if an LCT is attached. Open the LCT tray, remove the paper, check for folded paper, reinstall - should work ok. Usually a few bent and folded sheets of paper at the bottom of the stack borks the whole machine out for some reason.
        • emujo
          • Jun 2009
          • 3009
          If you are getting the stop print message, something has reached it's end. Look at the life counters in service mode...IU's Xfer belt, 2nd x-fer roller, fuser, filters wont generate the stop print. Emujo
          • kingarthur
            • 1325
            go into the enhanced security mode & set the print stop to "NO STOP", if you are a dealer, there is a bulletin on the infohub
