C1070 static problem
  • faultman
    • Nov 2009
    • 20
    Has anyone experienced a massive static problem on the C1070. When copies exit the machine everything appears fine but as the prints stack on top of each other they become stuck together with static. Happens on all types of stock and paper weights. Machine is brand new.
  • KM1Amsterdam
    • Jun 2014
    • 36
    Re: C1070 static problem
    I noticed that thin paper curls around the fusing belt, never though it would be a static problem.
    • Blizzoo
      • Aug 2013
      • 608
      Just my 2 cents,change the power outlet,make sure that you have the right voltage
      • tulintron
        • Jul 2014
        • 668
        Check if the power grid is grounded and the accessory is with Brooms grounding paper
        • eg101
          • Jan 2005
          • 131
          Tape a piece of Bounce in the exit area
          • methogod
            • Dec 2008
            • 921
            what kind of paper?
            what are the paper specs?
            what do you have the press set to (paper catalog)?
            • Michael Peters
              Hi. I have exactly the same situation on a new C1070 - although uncoated paper is less affected. Also the machine gives electrostatic shocks all the time! Have you managed to resolve your issues - if so, how?
              Michael
                • 23008
                I would make sure that the anti-static brushes are all properly grounded in the finisher. Perhaps I might try to add a few more anti-static brushes. =^..^=
                • methogod
                  • Dec 2008
                  • 921
                  Make sure your setting your paper correct. What type of paper and what weight.
                  We run all day and night and only have major static when we fold in our bindery...
                  Good Luck...
                  • MFPTech
                    • 486
                    What are the accessories for your machine? Is it using the dehumidifier?
                    • Michael Peters
                      I have a standard set up:
                      Bizhub C1070 Engine Only
                      Suction Fed Paper Drawers
                      Relay Unit
                      High Cap Stacker
                      EFI Fiery (Embedded)
                      we use mainly digital coated paper, that has given no issue on our other digital presses (past or present)
                      • Tech Helpdesk
                        • Jul 2015
                        • 112
                        The static will be eliminated with the fitment of the new RU517 this is supplied by K-M FOC.
