konica 6000/Fs532
  • rainmaker
    • Jul 2011
    • 77
    konica 6000/Fs532
    Got a problem I haven't find the solution.First I do have the service manual and have access to Konica.The problem only happens when I staple,more than one set.It jams as the second set come to the stacker and the follow sheet stop at ps 33.I have checked the sensor in the I/O mode.It does have about 7 mill on it.This problem just started happening.thought it was paper dust that was in the FS532 cleaned them.Like I said only when I staple.Doesnt matter what tray I use.I did order ps 33 and ps 32 and motor via service manual as well as the motor. thanks in advance jam code is 7227. did notice like the paper was over drivin
  • Albonline
    • Sep 2008
    • 1151
    Re: konica 6000/Fs532
    you have a solenoid thats not adjusted correctly
