c220 paper size
  • jonpaul
    • Jul 2014
    • 59
    c220 paper size
    We have a C220 where tray 1 does not recognize A3 paper it just comes upwith ???? no matter we do.
  • hotfuser
    • 180
    Re: c220 paper size
    the size detection fingers get bent out of position and do not register properly.
    if you put A4R in does it register correctly? i usually order the metal fingers and the sensor board.
    • MDR24
      • Apr 2013
      • 64
      Re: c220 paper size
      I'd check for paper behind tray 2.
      • dickierock
        • 252
        Re: c220 paper size
        There is a part (cassette holder bracket A0ED627500) that sometimes cracks and throws out size detection.
        • dickierock
          • 252
          Re: c220 paper size
          Check out part no.9.
            • 22997
            Re: c220 paper size
            Also, if the mechanical centering adjustment for the tray is adjusted all to one way or the other, sometimes you'll see the "???" paper size. =^..^=
            • printerguy77
              • Feb 2014
              • 26
              Re: c220 paper size
              Having a similar issue with both trays. does anyone know what the fix for this particular problem was?
