Bizhub C360 (DF-617) pulls multiple sheets
  • altech
    • Jul 2014
    • 41
    The doc feeder pulls multiple sheets through when it's gets down to the last 5 or so pages. I have replaced all of the rollers, the sep. pad assembly, and even changed out the whole doc feeder. The customer is running plain 8 1/2" X 11" paper through. Any solutions?
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: Bizhub C360 (DF-617) pulls multiple sheets
    Did you change out with a known good ADF? If so, there are adjustments to be made in service mode, also mechanical like height adjustment etc.
    • Kmdurrin
      Copy/Print/Network Tech
      • Dec 2008
      • 132
      Increase the resolution by one step to slow down the paper feed. The doc feeds on this series have multi-feed problems when the resolution is set to 200x200. This has worked for most of our C360s in the field.
      Parts: Its what your copier craves!
      • fishleg
        • Mar 2009
        • 426
        Can you change resolution for photocopying? Didn't think you could.
        Sent from my Nexus 5 using Tapatalk
        • altech
          • Jul 2014
          • 41
          No, you can't only for scanning/faxing documents.
          • EarthKmTech
            Step aside, noob
            • May 2009
            • 2139
            put the sep roller pressure spring into the lowest setting - default is middle.
            I am assuming you are running the correct, red feed and sep roller, not the older blue and gray as used in the c353 & c352 series, they are NOT interchangeable.
            • Phrag
              • Oct 2012
              • 417
              You could either a) Change the shaft and torque clutch on the Sep Assembly or b)use a fine sandpaper on the shaft where the torque clutch rotates/sits.
              If this is slipping, thus supplying less of a friction force, multiple sheet feeds are more likely.
              OR you could also add a little padding to the little plastic tabs on the pickup assembly so they sit up just a fraction higher.
              All these have worked for me.
                • 14812
                You have to remove sep roller and trim the mylar on the pre-sep pad. And also set the sep tension to the lowest level as EarthKmTech mentioned.
                Hope this helps.
