Bizhub 600 developer in a Di5510/7210
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    Has anybody tried this? We have a group of Di5510/7210s that we would like to use as fire came machines, but the developer has been discontinued and is no longer available from Konica. I know that the dev units are not compatible with eachother, but what about the developer itself?
    Parts: Its what your copier craves!
  • Woxner
    • Jul 2011
    • 848
    Re: Bizhub 600 developer in a Di5510/7210
    They are different. 5510 take Mt 604 and the 600 takes dv710
    • alexxcopier
      • 53
      i don't think so
      • smart-refill
        • Jan 2012
        • 27
        did you try to use developer of biz600 in di5510?
        • allan
          RTFM!!
          • 5462
          Yes i think you can use Dv710 you have nothing to loose. The 7210 engine is very similar. I check the toner conposition on the side of the OEM toners if that match the chance that you can use the develop in the diverent machines are good. The wieght of the developer could be diverent. I have used DV-511 in a b601 without problems the yield is cut in half if you only add one bag. Same with a DV-710 in a B501 but you must check the amount you add.
          i would not recomed doing this. Did this because there was no other option at the time.
          Whatever
          • xFuryx
            • Oct 2009
            • 18
            I am about to try a di510 dev unit in a di7210, according to the "differences to former products.pdf" another konica tech posted they should work.
