.original detection
  • luis8832
    • Dec 2008
    • 250
    [Misc] .original detection
    I have a C364e with a DF-701. When you lift up the cover and close it says original size detection but there is no original. I have tried it on other copiers and it just goes ready to copy. Any input is greatly appreciated.
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: .original detection
    Find the setup instructions for the doc feeder and re-do them. You may also need to adjust the heigth of the front edge a little higher than stated as well.
    • kingarthur
      • 1364
      take the glass out & clean it both sides, have had a couple do this, the last one all i did was wipe my hand briefly across the glass......some i've had to clean a few times
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        also make absolutely certain the white backing sheet on the adf is absolutely spotless in the detection area.
        a single speck of filth will cause this in the right place.
        • habik
          • 2013
          As EarthKMTech said, I had this couple of times!
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
            • 14778
            Make sure the magnet on the DF lines up with the reed switch under the front cover of the scanned bed.
            • copierguru
              • Jul 2011
              • 27
              As stated clean the under side of the glass and clean the size sensors. Common problem with these machines
