Abort screen when Printing and scanning
  • Cookr
    • Dec 2011
    • 184
    [Misc] Abort screen when Printing and scanning
    Have a customer who gets the blue abort screen when they try to print and/or scan but they can make copies with out a problem. I was there today and it was working fine of course but last week apparently the entire office (about 10 people) could do nothing. any ideas? thanks
    Oh yeah it's a Bizhub 250
  • darry1322
    • Oct 2010
    • 817
    Re: Abort screen when Printing and scanning
    Possible MFB board failure, although they usually cause abort codes for copies as well.
    • EarthKmTech
      Step aside, noob
      • May 2009
      • 2139
      Itd be worth knowing what the abort code is because it may tell us something.
      I've had machines of this series throw abort codes for stupid things like having the scanner lock partially engaged too. not enough to throw a malfunction code, but enough to cause the software grief anytime the document feeder was used.
      • HoonBoy
        • May 2011
        • 130
        Indeed there are quite a lot of codes... One of the frequent ones I encountered was because a IP conflict...
        • copytechman
          • Nov 2008
          • 929
          That'll do it or even some sort of corruption in the IP programming... Had to switch the programming to a different address, reset, then put it back again and reset before one stayed stable once..
          Regards!
          A.
