bear pod switches for vendor mode 2
  • leoS6N
    [Misc] bear pod switches for vendor mode 2
    Does anyone know the swich configuration for the bear pods for vendor mode 2 on KM gear
  • TheOwl
    • Nov 2008
    • 1732
    Re: bear pod switches for vendor mode 2
    I don't know what all the switches do, but I do know that switch 3 cancels clicking for scanning.
    Otherwise, we have left all the ones we have installed in their factory position and have only every needed to change switch 3 for one machine only.
    • Hansoon
      • Sep 2007
      • 3383
      WTH are "bear pod switches"?
      Hans
      • TheOwl
        • Nov 2008
        • 1732
        BEAR Solutions make a cost recovery system as well as terminals that interface to the copiers.
        The BEAR Pod is what they call the interface unit which interfaces the terminal to the MFD.
        • Hansoon
          • Sep 2007
          • 3383
          Thanks Owl.
          Hans
          • leoS6N
            The bear pod is the device that communicates between the MFP and the "Coin box/ authentication device" inside there are 10 hard switches to set to your needs.
            i found out that vendor mode 2 requires 7 & 10 to be set to on.
            TheOwl was correct 3 is scan, 4 is fax and 5 is print
