license management error
  • nezzy2120
    • Mar 2009
    • 13
    [Error Code] license management error
    I have a C550 I had to do a nv ram reset. After that I got the message License management error.How can I fix this with out calling Konica minolta
    • 23010
    Re: license management error
    Somehow, I get the feeling you don't actually read the responses to your posts:
    http://www.copytechnet.com/forums/ra...tml#post427875
    Just because you don't like the answer, doesn't mean that it isn't the answer. Asking three times will not change the answer.
    Call a KM dealer. That's it. The end. =^..^=
      • 14873
      I'm not sure if this will help you with your C550, but I have had License management errors on three C353 series machines and replacing the EEProm has fixed it all three times. I didn't have to call KonMin once.
      Hope this helps
      • ck1
        • 485
        Hope this helps
        But the problem is where to get new EEPROM ? get from form KM ? what different call KM ?
        • CopyJunkie
          • Oct 2012
          • 28
          I had a Bizhub 601 come up with a license management error after wiping the HDD. A technician can use the License Management Server to request a initialization code which should reset it.
          NOTES ON HOW TO USE THE FAX MACHINE.
          1. Get into your DeLorean (or your TARDIS) and go back to 1990.
          2. Place papers in the machine - Face Down.
          3. DO NOT dial 9
          4.
          Rejoin the rest of modern civilization.
