konica 1312 f34 error
  • simple_john
    hi we have an older konica 1312 copier. it has 93,900 page count and shows an F34 error when it turns on.
    does anyone have any idea as to that code? its out of service and i dont have a repair manual.
    Any suggestions would be appreciated. Thanks
    sj
  • ni311
    • May 2008
    • 658
    F34
    Fusing high temperature abnormality
    The fusing temperature exceeds the specified temperature. (Detection temperature = 225°C)
    Konica Minolta Error Codes - Explanations and Solutions
    • simple_john
      thanks, is there anything i can do to prevent this from coming up? replace the fuser? or is there a reset anywhere? it gives me that error the second its powered on.
      thanks
      • deep
        • Jun 2008
        • 208
        Don't try to reset the code before the fuser unit is being checked and fixed. The Job must be carried out by a qualified tech.
        Kenny
        • copycommerce
          • May 2008
          • 65
          There are one or two thermistors at the fuser.It depends of the model.I can say that probably one of the thermistors is dirty with toner.U need to clean it with AMB.If the thermistor type is with two plates u need to separate 'em.Then reset the code and all should be fine.Some of the old analog machines are one of the strongest and very easy to service.
          • simple_john
            Thanks for the info, im trying to find the manual to see if it will explain how to get at the fuser and how to reset the error code..
            thanks for the help
            sj
