C352 registration issue...
  • blax
    • Mar 2013
    • 78
    hello
    this machine can not be adjusted manually, registration is not good... technician cleaned registration roller, IDC, replaced transfer belt, and several times trying to adjust registration but max supported value is +6....
    some ideas about it?
  • Max
    • Oct 2011
    • 561
    Re: C352 registration issue...
    My guess is the copier cant see the pattern on the I.B because one or more I.U worn out or laser class covered in dirt. Print out solid c y m k test patterns and see witch one is playing up.
    • blax
      • Mar 2013
      • 78
      yes, i done that and all CMYK IU are working well,,, sheet is 100% covered without issues or scratches...
      any more ideas?
