Konica minota bizhub 751
  • Nhimbob
    • Jan 2013
    • 10
    [Electrical] Konica minota bizhub 751
    Hi..
    Please help me
    I have bizhub 751 only copy by bypass, tray 1,2,3,4 and ADF can not be used currently
  • Zackuth
    • Aug 2009
    • 448
    Re: Konica minota bizhub 751
    First check and make sure the trays and ADF haven't been turned off in the service mode.
    If at first you don't succeed, redefine success
    • Albonline
      • Sep 2008
      • 1151
      there is a one way clutch behind the bypass unit that has taken a crap.
      • Nhimbob
        • Jan 2013
        • 10
        Hi...
        Thank you for your answer, ask you one more question this machines only copy 150 sheets how to fix it.
        Thank you very much
          • 14735
          Originally posted by Nhimbob
          Hi...
          Thank you very much
          I think we may need a bit more detail.
          • Nhimbob
            • Jan 2013
            • 10
            Ok, That mean when I copy 500 sheet the machine only copy 150 sheet and stop, I must touch continue on panel to copy.
            • Downunder
              • Aug 2007
              • 174
              Hi..
              Please help me
              Does the paper get fed from the cassettes, and if so where does the paper stop. If it stops in the vertical unit it could be that the drum pawl solonoid wires have been shorted out on the bearing on the main shaft. Remove drum unit and check at rear of drum unit. If it has shorted you will need to replace print control board. (ICP blown)
