C280
  • jonpaul
    • Jul 2014
    • 59
    [Error Code] C280
    We updated firmware and scanner came up with download NG.It then threw code CC152 what gives?
  • copier tech
    • 8172
    Re: C280
    Sounds like your firmware was corrupt, download it again then flash the firmware again
      • 14812
      Re: C280
      Because of the earthquake/tsunami in Japan in 2011 the scanner board is different on some of this model. There is specific scanner firmware for this situation.
      There is a serial# start point, but I don't know where it starts.
      Hope this helps
      • laitang
        • Nov 2012
        • 627
        • wseyller
          • Sep 2012
          • 1129
          If it still don't work you can probably download an older firmware and just install only the scanner portion to get it back up and runner. This method has helped me before.
          • Las Kona
            Re: C280
            Before upgrading firmware always check if you have that is to upgrade, meaning the software must be all be up to dated.
