Squares on the copy ineo+ 224e
  • GTgosu
    • Mar 2013
    • 19
    [Misc] Squares on the copy ineo+ 224e
    sorry for my english..
    I have a problem with copies, every few pages appears squares, sorted like a black fields on chessboard.I update the firmware and SSD board, did not help, any advice or suggestion?
  • Mr Spock
    Vulcan Inventor of Death
    • Aug 2006
    • 2064
    Re: Squares on the copy ineo+ 224e
    If this is a rebadged Konica Minolta then find the original setup instructions and redo them step by step.
    • GTgosu
      • Mar 2013
      • 19
      I try three times instalation process, but it didn't help. In my c224e+ i can't find touch panel adjustment option(in access), without that, instalation can pass ?
      • copier tech
        • 8131
        The new C224e machines do not have the touch screen ajustment, this was removed in the latest firmware.
        But yes if this is a new machine perform the installation setup procudure follow it to the letter, setting the time, austion gradation etc
        • GTgosu
          • Mar 2013
          • 19
          i try tip from instalation manual "Please replace the procedure currently listed with the following one below from "XII. Adjusting touch panel" to"XVIII. Date/Time setting (Administrator settings).""
          but didn't help any idea what can i do?
          • copier tech
            • 8131
            Can you post a sample of the fault, perhaps say the Demo Page.
            • GTgosu
              • Mar 2013
              • 19
              Are you looking my file attachment?, there is scan how my ineo224 works.
              • Synaux
                • Mar 2012
                • 1224
                This does not look like the typical installation error.
                I vote try testing, swapping or replacing the memory modules.
                Hope this helps
                • copier tech
                  • 8131
                  Thanks just seen your sample, & yeah this is not the installation print error, with that you get cyan lines.
                  Gave you got any P-codes? look for the oil can when you enter service mode at the top?
                  • GTgosu
                    • Mar 2013
                    • 19
                    i haven't got any P-code and no oil icon in the service mode.
                    My machine has only 17000 page counter. And this problem appeared when it has 15000 page on the counter.
                    I try to switch memory modules.
                    • Synaux
                      • Mar 2012
                      • 1224
                      Also, if the DIMMs looks dirty in any way try using a pencil eraser on the gold connectors and finish up with 91% alcohol and a rag
                      Also, check for other error codes (like cf codes), you can try a memory test in Service Mode before playing with the DIMMs, but that is not a definitive test. You could also try a data clear....
                      I am almost certain that this is a data issue, so also look at cables that pertain to data transfers.
                      Good luck!
                      *EDIT* I just realized you mentioned that happens on "copies" do this mean this only happens on scans/copies?
                      OR do you mean it happens with internal tests (e.g., service mode) and printing from a computer too??
