Bizhub 283 Network or Machine issue
  • erodz85
    • Mar 2011
    • 10
    Hey all, i have a 283 That won't print, won't email, but will copy. I can ping the machine, but i can't access pagescope. updated to latest firmware today, still no change, except the machine says "Waiting for ARP Request" when i enter admin mode on the panel. Been that way for about 20 min. Any ideas?
  • SmellsHot
    Head Tech
    • 512
    Re: Bizhub 283 Network or Machine issue
    turn on dhcp or manually configure the ip settings
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • erodz85
      • Mar 2011
      • 10
      Network settings tab is unavailable when this is displayed. I can't do anything having anything to do with network communication on this machine.
      • JR2ALTA
        • Feb 2010
        • 2033
        Try to ping that address with the machine unplugged. I have a feeling you'll get a reply, which means there's another device on the network with that same address.
        • Mr Spock
          Vulcan Inventor of Death
          • Aug 2006
          • 2064
          These machines did not come standard with a print controller. They would scan to email without it. Look on mfp pwb and see if the ic chip is installed.
          • copytechman
            • Nov 2008
            • 954
            Its a bh283, they came standard with print/scan, the bh421 series however required an ic chip for print.
            Regards.
            PS. Backup your data, maybe do a mem clear/ nic clear. Is there no network button in the admin menu@ the control panel?
            Regards!
            • mo0651
              • 1054
              Does it have a hard drive?? option for that machine.
              • EarthKmTech
                Step aside, noob
                • May 2009
                • 2139
                initialize the network controller in service mode, system 1 initialize (from memory)
                After the restart it will then default to automatically obtain an address but should time out after a few minutes and allow you into network config.
                • Mr Spock
                  • Aug 2006
                  • 2064
                  Regards.
                  Regards!
                  I stand corrected..
                  I did not have my manual and was thinking of the 421 family.
