Hi all,
Need help with this one please, been to look at a C552 with c-2557 (K toner dens low) I fitted a new K IU & toner as per the manual but no change. In service mode looked the K toner density level it was around 3%, Magenta & Yellow were at around 7%, Cyan was also low at around 4%.
So I manually added black toner (taking some out of the toner bottle & pouring it into the K dev unit, not ideal I know) to bring up the density level & this worked, K density went to around 7-8% however now the machine threw a C-2551 error, Cyan density low, so I did the same manually added Cyan toner, now all the levels are around 7% & the machine is working fine, however on a 100 full colour run all the levels drop & down & don't seem to go back up, even if I run manual toner add in service mode!
What should the toner density levels show, around 5%???
Manual says possible faulty PRCB, anyone seen this before????
