Konica Minolta C280 making clunking noise on idle
  • Alex1
    • Oct 2012
    • 285
    Hi,
    I have a Konica Minolta C280 making clunking noise on idle after moving the machine. I'm trying to see what it is that rotates on idle to make the sound even sometime on the first print it would make the noise for 3 to 4 seconds then stop any ideas? Maybe what ever turns on idle is the problem?? Thanks in advance.
  • copier tech
    • 8179
    Re: Konica Minolta C280 making clunking noise on idle
    My first thought would be the fuser
    • minimerlin
      • 851
      Originally posted by Alex1
      Hi,
      Transfer belt cleaner coils seized...waste chute from it to the waste box is clogged up?
      Please do not PM me without asking first.
      • Alex1
        • Oct 2012
        • 285
        That's what I thought but I removed the fuser and reseated it just incase and it still made the noise.
        • Alex1
          • Oct 2012
          • 285
          Is that more likely what it can be? I also tried removing the ITB and reseating it back into place and still made noise. I didn't pull the ITB all the way out though.
          is that what moves on idle?
          • copier tech
            • 8179
            The fuser is the only part that idles, the transfer doesn't
            • EarthKmTech
              Step aside, noob
              • May 2009
              • 2139
              Transfer belt DOES periodically move an increment at a time at idle.
              if you have a blocked cleaning section and chute this will be exactly what it is,
              • minimerlin
                • 851
                Sorry to be a pain but..it does!!
                • JSC
                  Gimp
                  • Dec 2006
                  • 618
                  i agree.
                  any noise reported on this model, my first port of call is the transfer belt cleaning assy & the waste Shute.
                  The gene pool could use a little chlorine.
                  • Alex1
                    • Oct 2012
                    • 285
                    Originally posted by JSC
                    i agree.
                    thank you for your help I will give it a go in cleaning it out.
                    • Alex1
                      • Oct 2012
                      • 285
                      • Alex1
                        • Oct 2012
                        • 285
                        i agree.
                        Just to confirm would I need to remove the ITB out and clean the the blade outlet? Also is the chute that leads from the ITB cleaner to the waste toner bottle in the front that needs to be cleaned?
                        • EarthKmTech
                          Step aside, noob
                          • May 2009
                          • 2139
                          2 screws removes the whole cleaning section off the belt. vacuum it out and clean its exit port and make sure its not blocked.
                          the chute is at the front of the machine and removed via 1 screw at the front door. take note of its installation, if you've not done it before it may be "fun" to reinstall
