C-1183 Error Message - Konica Minolta BizHub C353
  • CCI1
    • May 2025
    [Error Code] C-1183 Error Message - Konica Minolta BizHub C353
    Hello,
    I moved a Konica Minolta BizHub C353. Well, the printer got to the new location, but we are getting a C-1183 error message and our top side tray was broken off. I have attached pictures.
    Is there a way to bypass this error message. I checked the trays for mysterious jams, removed all the trays and old paper.
    Any suggestions would be helpful.
  • laitang
    • Nov 2012
    • 627
    Re: C-1183 Error Message - Konica Minolta BizHub C353
    Which finishser in used? FS-519 or FS-609?
    • CCI1
      FS-519
      • darry1322
        • Oct 2010
        • 817
        If you don't have an exit tray on the finisher, you will get an 1183 code. The tray is what activates the elevator home sensors.
          • 22927
          Yeah. It looks to me like the tray was just removed and not reinstalled after the move. You'll need to manually run the motor down a little, and re-install the tray.
          This is normal practice for moving a machine. These trays can get broken easily if left attached while moving. =^..^=
          • CCI1
            Thanks.....ITS FIXED. I had to jewelry rig the broken tray, but got it back on and restarted it. I also had to tighten up some screws. It took a little beating when it was moved.
              • 22927
              It may be possible to get a used or new tray. You should buy it now, because this machine will be considered obsolete very soon. Check with your local dealer. =^..^=
              • Kidaver
                Ghoulscout
                • Apr 2011
                • 912
                I have a C451 with finisher that sits over near the dispatcher next to a doorway that threw this code on me....couldn't figure it out at first so I set up another C451 we had in shop to kinda get an idea how the finisher raises and such...turned it on without the trays and threw same code...that's when it dawned on me it was the trays lol....seems our sales people coming thru the door way to get print jobs and such knocked the tray loose and caused it to code out....then yesterday another C451 in our printshop girl down there asking me what is causing this C 1183 code....I told her it was the tray she was holding in her hand lol
                "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
