bizhub C224 error C-6102
  • backspace
    • Jul 2009
    • 54
    Hi,
    i have code 6102 on bizhub C224 (Scanner). I try FW, clean, reconnect, test lamp, test home sensor, trouble reset, initialization - clear error. And problem still persist.
    How i can test scenner motor?
    I am also tech.
    TNX
  • laitang
    • Nov 2012
    • 627
    Re: bizhub C224 error C-6102
    Originally posted by backspace
    ...How i can test scenner motor? I am also tech....
    Why not replace and try?
    - scanner motor
    - scanner drive board
    - printer control board?
      • 23009
      Hi,
      I am also tech.
      TNX
      I've heard that some techs read manuals, and sometimes find the information all by themselves. =^..^=
        • 14788
        I'm sure that is one of those urban legends, cat.
          • 23009
          I suppose its a lot easier to get some dumbass to look it up for you on a forum. =^..^=
          • backspace
            • Jul 2009
            • 54
            Thanx anyway....
            • toner cartridge
              • Sep 2014
              • 33
              Hi,
              I am also tech.
              TNX
              it is problem MFP board, try to check.
              Toner Chip Supplier
              • emujo
                • Jun 2009
                • 3009
                Unfortunately, the ability to test motors and solenoids has been omitted on most of the newer K products. But as a test, you can try turning the MFP on and watch for the scanner (scenner) to move. If it moves to the home position, and the lamp lights you can probably rule out the motor and lamp (capt obvious!!!). If it has the dual scan (701) you may want to look at 2nd side board, and ribbon cable. Also ensure you have the right DF selected in service mode. Emujo
                • EarthKmTech
                  Step aside, noob
                  • May 2009
                  • 2139
                  I seem to recall hearing about this from a tech recently. There is a bulletin about this, but I'm afraid I CBF looking for it sorry.
                  • occus
                    • 337
                    In my case it was the PCRB... and not the scanner board! (PRCB are the last position to fix the error on the bulletin)
                    • backspace
                      • Jul 2009
                      • 54
                      I slove this it is problem with:
                      1. scanner motor
                      2. scanner drive board
                      I had to replace both parts.
                      TNX
