C554e job doesnt start printing until the machine receives the entire job
  • vinnysamways
    • Jul 2025
    [Misc] C554e job doesnt start printing until the machine receives the entire job
    When printing a mail merge word document to a Bizhub C554e it would appear the job does not start printing until the device has received the entire job. It also looks like as soon as we select duplex on the job the size of the job increases 10 fold??
  • sauce_boss
    • Oct 2011
    • 26
    Re: C554e job doesnt start printing until the machine receives the entire job
    Give this a shot
    Solution ID
    2
    Solution Usage
    TAUS0703717EN*
    Description
    All duplex jobs spool completely before starting to print.
    Solution
    CAUSE: Paper Arrangement is set to Prioritize Arranging Papers under the Finish tab in the driver.
    SOLUTION: Set the Paper Arrangement to Prioritize Productivity. If speed is an issue this should be set as the default.
    • TheOwl
      • Nov 2008
      • 1732
      Mail merges sent from the Office suite are always treated as one job. You will also find that if you go to staple as well, the device will try to staple the entire print run.
      Below is a macro that I have been using for years which should get you out of trouble.
      Mail Merge.pdf
      • D Colour
        • Oct 2008
        • 213
        In printer properties, under advanced, make sure "Start printing immediately" is selected rather than "Start printing after last page is spooled."
        Everything that has a beginning, has an end.....
        • vinnysamways
          Thanks for all your help guys, all sorted now!
          • Hansoon
            • Sep 2007
            • 3384
            So what was the solution, the "Start printing immediately" thing?
            Hans
            • habik
              • 2013
              In my experience the solution to MS office stapling multiple copies of the same doc as one bunch is to uncheck the Collate box in printer dialog. Simple as that! MS office= Logics out! Or Think out of the box! Pun intended!
              Sent from my iDon't believe in marketing device using Tapatalk
              Firmwares HERE
