Yellow background & black stripes (lines) BIZHUB C452
  • donrushs
    • Sep 2014
    • 21
    Hello,
    Yesterday i managed to fix REPLENISH TONER ERROR through an electric technician not a KM technician who examined and fixed the problem on prcb (motherboard), where the problem was on ICP19 and not ICP5, and now the yellow toner is detected, but now i do experience another problem, whereby every printout come with a yellowish background during printing and when photocopying it came out with yellowish background and black stripes (lines) from the top to bottom of the document.
    what could be the problem and how to fix it.
  • Max
    • Oct 2011
    • 552
    Re: Yellow background & black stripes (lines) BIZHUB C452
    I would say the board is not fixed. The lines are due to fault in image processing/memory issue. Yellow is probably over toned dev unit. Change the MFP board to a brand new and not repaired. The only problem is they cost a fortune.
    • donrushs
      • Sep 2014
      • 21
      Where can i get New MFP Board (prcb), i decided to repair the board because its too difficult to get a brand new board here in Tanzania.
      • Synaux
        • Mar 2012
        • 1224
        Please do not create redundant/similar posts!
        • roberto.bertolani
          • Feb 2012
          • 19
          I had the same problem in scan mode FTP and changed MFP.
          she really cost much
          the problem was due to RAM soldered in MFP
          bye from Italy
          • fishleg
            • Mar 2009
            • 426
            Curious about icp's on boards how did you replace it? Are they just tiny fuses if so how do you know voltage, ampage etc?
            • Synaux
              • Mar 2012
              • 1224
              I am not sure about the PCRB, but I am assuming they are about the same thing as the ICP5s on the Print Relay Boards.
              If this is correct, then you would have to desolder the chip and solder a new one on....
              Take a look at this:
              Toshiba IC5 on PWB-J Relay board for PH unit C650.pdf
              • fishleg
                • Mar 2009
                • 426
                ICP just a small fuse tho?
                • Cookr
                  • Dec 2011
                  • 184
                  I had a similar problem on a Muratec C2280 the lines were caused do to it not being set up properly maybe when the board was fixed something happened??
                  http://www.copytechnet.com/forums/mu...nes-c2280.html
                    • 22999
                    It looks to me like the "Lines of Shame".
                    Have you gone through the machine's initial setup procedure line by line? (Just the part that begins when you plug in the machine.) I think it will resolve the problem. =^..^=
                    • donrushs
                      • Sep 2014
                      • 21
                      LOL........ the problem already solved, just got an assist from a technician and he did an initial setup procedure, and then the problem solved.
                        • 22999
                        Congratulations. =^..^=
                        • Josh93
                          • Jul 2014
                          • 47
                          HA lines of shame.... I'm going to use that the next time I head out to a clients to clean their scanner glass. "I clean it 5 times!!!???" After two seconds on site with a rag... "Oh how you do that"??
                          Lines of shame...
