Bizhub c353 line
  • mariolo
    • Aug 2014
    • 5
    Bizhub c353 line
    hi guys, this is my first post , i have a c353 printing an horizontal line, i attach pictures. Im new at this and been reading a lot, but i just dont know where do i begin first solving this, my counters for image units are 8/10, fusing unit 8/10, and transfer belt 6/10, thanks
    c353.pdf
  • Tonerjockey.com
    • Jun 2010
    • 41
    Re: Bizhub c353 line
    Does it occur on both copies and prints? Run a test page and see if you get the same result.
    Also if you run only in gray scale does the same thing happen?
    • wseyller
      • Sep 2012
      • 1129
      Run halftones of each color from the test menu in service mode. This will show you the quality of each color CMYK. If no issue could be in the scanner. See if issue happens when copy from glass and/or document feeder.
        • 22997
        It's as I thought. If you do the color math. red less yellow equals magenta.
        Or you could use Colorpic to see that it's the yellow that's diminished in that line, I'm assuming in the feed direction. The most likely solution is:
        1) dirty laser slit glass for yellow. Use the wand (either in the door or hidden in one of the trays).
        2) contamination under the doctor blade of the yellow developing unit. An area of poor fill could be seen on the developing roller. An experienced tech may be able to disassemble the yellow imaging unit far enough to retrieve the blockage. Or you can replace the yellow imaging unit assembly. Either way is fine.
        • mariolo
          • Aug 2014
          • 5
          [ATTACH=CONFIG]26683[/ATTACH]
          im gonna try to clean it, thanks
          it occurs on both copies and prints, in color only
          its not the scanner i get the same results on copy and print
          • mariolo
            • Aug 2014
            • 5
            the only problem is yellow as attached on the pdf, a tech came to check my imaging unit but didnt found any blockage, ive cleaned the laser with the wand and still no change :S, maybe i need to change the whole image unit :S, what do you think guys??
            Y.pdf
            • WATTY
              • Oct 2014
              • 12
              [ATTACH]26682[/ATTACH]
              Hello
              looks like one of your process units has some muck behind the doctor blade, try running half tones test pages for lines on each colour.
              Good luck
              • mariolo
                • Aug 2014
                • 5
                Originally posted by WATTY
                Hello
                Good luck
                the blade in the drum or the blade in the developer?? sorry for that question im really new at this :S
                • WATTY
                  • Oct 2014
                  • 12
                  behind the doctor blade in the dev , its a all in one unit so might be worth changing it, do you half tone test pages from lines in each colour.
                  • mariolo
                    • Aug 2014
                    • 5
                    here they are
