Few more issues with Bizhub 200
  • eli
    Not a technician
    • Oct 2014
    • 40
    1. Double sided printing isn't working. I don't think its a driver issue although I did set "duplex: installed" option. I wasn't able to copy a double sided document. It ended up printing on both sides.
    2. I can't access the printer from the web. It worked fine before but now all I get is "This page can’t be displayed"
    3. No matter what I've tried, I just can't get email option to work. I tried every smtp setting out there and still something is wrong. I'm using smtp-relay service through google apps for business. I'm able to send thru my website and other services but not from the printer. Also tried regular gmail smtp and apache mail client with no luck.
    Most important issue is #1.. What are the troubleshooting steps? Thanks in advance.
    edit:
    No option to print double sided?
    edit 2:
    Duplex set signal is showing 1 in I/O check
    I printed the settings page. Under Printer information -> option -> duplex unit is equal to none.
    • 23009
    Re: Few more issues with Bizhub 200
    Can you be a little clearer with your terminology? In the first sentence you say that duplex printing isn't working, then in the last sentence you say that it is working. Which is it? Contradictory statements like this make me distrust the accuracy of any statements that follow it.
    What browser are you using. Have you tried a different browser choice? Can you print? Can you ping the printer? Does it accept a telnet print job?
    Are you trying to send email SSL or Start TLS? The bizhub 200 can't use SSL or Start TLS without an external utility like Stunnel.
    edit:
    edit 2:
    It seems to me that you are using the terms copy and print interchangeably, when they are not. Copying is copying, and printing is printing. I'm going to make a WAG that you cannot duplex copy because the duplex option is not Set in copier's service mode.
    Would you care to clarify your previous statements? =^..^=
    • eli
      Not a technician
      • Oct 2014
      • 40
      Thank you for your reply. I made a mistake and I apologize. What I meant to say was, when I pressed "copy" on a double sided document, it printed each side on a separate page. Before attempting to copy, I was trying to print double sided documents from Microsoft Word which didn't work. I made sure to select all the right settings, like "Duplex: Installed" and nothing solved it. After this, I went into I/O mode and the duplex cover sensor seemed to be working. It did say "Duplex Set 1" though, not sure what that means. The fans seem to be working on the unit and I've cleaned everything carefully with alcohol just like it said in the service manual.
      Am I missing some settings?
      Also, please check the following images. They will give you a better idea on what's happening.
      About the web page, yes I've tried different browsers, chrome and IE.
      Chrome gives me a following error:
      SSL connection error
      Unable to make a secure connection to the server. This may be a problem with the server, or it may be requiring a client authentication certificate that you don't have.
      Error code: ERR_SSL_PROTOCOL_ERROR
      I'm able to print just fine, scanning to folder works and no problems pinging the copier.
      About email, yes I tried mostly SSL. I did try it without SSL but that didn't work also. Looks like I need to try it with that Stunnel utility.
      At last, how do I enable the duplex option in copier's service mode?
        • 23009
        ... It did say "Duplex Set 1" though, not sure what that means. The fans seem to be working on the unit and I've cleaned everything carefully with alcohol just like it said in the service manual.
        [ATTACH=CONFIG]26727[/ATTACH][ATTACH=CONFIG]26728[/ATTACH][ATTACH=CONFIG]26730[/ATTACH]
        Change Duplex unit Set to "0". =^..^=
        • eli
          Not a technician
          • Oct 2014
          • 40
          Can you please tell me how do I do it? I just can't seem to figure it out and the manuals aren't being too helpful. Keep in mind, I'm not a copy machine tech.
            • 23009
            I was wrong about that. According to the brochures the 200/250/350 all come with a standard duplexer. It's not optional, and is not treated as an option. The setting in tech rep mode selects whether you'd like the selections of Simplex and Duplex, or just Duplex. There is no non-Duplex option.
            Duplexing is the least of your worries. What are you going to do about that drum? =^..^=
            • eli
              Not a technician
              • Oct 2014
              • 40
              I think the drum is alright for now. It printed that one page like that but then other pages were clean.
              • wseyller
                • Sep 2012
                • 1129
                Make sure the connectors for the switchback unit (above fuser) are plugged in. This can cause the duplex options to disappear from the copy menu.
                • eli
                  Not a technician
                  • Oct 2014
                  • 40
                  Is this it?
                  This is what I see. Seems like the middle one is missing a plug
                  • wseyller
                    • Sep 2012
                    • 1129
                    Yes that's it. Middle connector missing is ok. That is for some optional accessory.
                    • eli
                      Not a technician
                      • Oct 2014
                      • 40
                      Everything was plugged in, i didn't see anything unplugged.
                      So this is not the problem. What else can i check?
                      • 907tec
                        • 434
                        I would keep looking at that switchback unit. Confirm that you are getting power at the connector and that the wires have not been damaged. Very easy for people to pinch those wires when reinstalling the switchback. Do the switchback sensors change state in service mode?
                        • HuronMan
                          • Jul 2009
                          • 68
                          edit:
                          I just had to make a bh250 do this today. It has a jam indication that I can't get rid of and is unusable so I unplugged the duplex unit and got the screen you posted above. Now it at least runs 1 sided. The duplex connector is the multi colored wiring harness behind the the Lower Right Rear Cover. The same cover to unplug the bypass and tray2. Check that and connector pj20 on the pwb-a.
                          • eli
                            Not a technician
                            • Oct 2014
                            • 40
                            How can I check that power is going into it? I didn't see any damage done to the wires. I doubt they replaced anything in this machine, it only has 20k prints on the counter.
                            I opened it up and found those wires and connectors. Seems like everything is plugged in and nothing is cut. I think duplex is connected because the fan works.
                            Here are the photos
                            • darry1322
                              • Oct 2010
                              • 817
                              Those pictures are of the transport/transfer section and are not part of the duplex unit.
