firmware issu
  • Riyadh hossain
    • Aug 2025
    firmware issu
    For firmware storing needs USB stick 1GB or less and FAT format .But now 1GB or less usb stick is not available in market ,
    Have any alternate way to store firmware files for firmware update????
    Sometime I use 4GB,FAT32 format but all time it does not work and vanish automatically, when I insert in pc,pc show need to format before using this device . Have any solution about USB stick for firmware update????? please help
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: firmware issu
    I use a sandisk 4Gb usb stick formatted in FAT32 format for updating fw on all USB capable machines without issue.
    I also have an old kingston 4Gb stick I have been using almost every day for 5 years which is still faster, unfortunately it is starting to fail to be recognised by the computer and copiers and or corrupting the data resulting in download n.g. If i could find more new old stock of these i would buy a box full it has been awesome.
    • sanimir
      • 183
      Re: firmware issu
      make 1 gb partition on larger stick
      • copier tech
        • 8169
        Re: firmware issu
        You can get good quality 2 gb drives on eBay, the are so cheap I keep one for each machine & update them every couple of months
