error code c-6104 bizhub c224e
  • reli
    • Oct 2014
    • 6
    hi, I have already change the sensor PS7, motor and the board for the df 701 , any others suggestions.
    Thanck you
  • kingarthur
    • 1385
    Re: error code c-6104 bizhub c224e
    There was a bulletin about replacing one of the RADF cables
    • reli
      • Oct 2014
      • 6
      Thank you for the reply, to day I replace a complete fede df 701 same problem. I change also the memory same problem.
      Bulletin witch number
      • EarthKmTech
        Step aside, noob
        • May 2009
        • 2139
        If the second side brush is stalling in the gain adjustment position and the paper stops dead in its tracks and then throws the code, replace the mfp board.
        (after you have replaced the black second side CIS cable first as these ALWAYS fail, you have already done this by changing adf, so go ahead with board and let me know)
        • reli
          • Oct 2014
          • 6
          thank you, I am ordering the mfp board under warranty. I let you know. Have a good week end.
          • reli
            • Oct 2014
            • 6
            Hi, we replace the machine. But now I am working on the problem at the showroom. so, i am ordering the mfp board. Thank you
            • B0265
              • Jan 2007
              • 718
              Did a new mfp board solve this?
