C654e P-14
  • wseyller
    • Sep 2012
    • 1129
    C654e P-14
    IDC sensors cleaned but no help.
    What should I look at first? 53,000 on total counter.
    Color IUs, black drum, print head. Any service mode adjustments I can try?
  • laitang
    • Nov 2012
    • 627
    • allan
      RTFM!!
      • 5462
      Re: C654e P-14
      The K drum and the C drums are not the same diameter. so there is a separate encoder on the K unit to check the surface speed of the drum. if that sensor or encoder disc is not ok you will get that code. you can try manual color registration but the would drive you crazy it would shift randomly. if noting else works replace the encoder.
      Whatever
      • wseyller
        • Sep 2012
        • 1129
        Re: C654e P-14
        Looks like it finally went away on its own. I check IDC sensors really good. Check IU contacts. Did an initialize + stabilization and gradation. Halftones per perfect.
        • Blizzoo
          • Aug 2013
          • 608
          Re: C654e P-14
          P-14,as per manual says,can occur when a door is opened or Main SW turned off when machine runs the skew correction control.
            • 8167
            Re: C654e P-14
            On this "e" series it's always a good idea to update the firmware, KM seems to bring out new FM on a regular basis for this series
            • wseyller
              • Sep 2012
              • 1129
              Re: C654e P-14
              Oh I did that too. There is a J6 that was release during the week.
              • pgramolini
                • Sep 2014
                • 19
                Re: C654e P-14
                They definitely do. It's new... Ish
