C-E301
  • emujo
    • Jun 2009
    • 3009
    [Error Code] C-E301
    Have had this code numerous time in the past, and have usually been able to resolve it either through hardware, or firmware, but this time I am at a brick wall. Original tech went out to look at a fuser jam issue. He replaced fuser drive motor and 2nd transfer roller. On initial power up MFP threw the C-E301 error. Thought he may have induced something so I have spent the better part of 3 days trying to resolve this. We have replaced 2 MFP boards (new, and used, used was added with the initialize tool). SSD, memory, and HDD. No matter what we try, it will get past the splash screen, copier screen pops up for about 1 sec and then into C-E301 code. Self test runs with all OK. Have tried numerous firmware levels including J5 (or is it J6). Running w/o accessories, with, w/o HDD. No change. Anybody run into a hard CE301 that you were able to finally resolve? Emujo
  • MVPunisher
    • 209
    Re: C-E301
    Acquire the debug logs in [Service Mode] -> [Debug
    Settings] and analyze them.
    • MVPunisher
      • 209
      Re: C-E301
      I would try the 2gb memory in there.
      • MVPunisher
        • 209
        Re: C-E301
        my bad just saw that you did that.
        • WATTY
          • Oct 2014
          • 12
          Re: C-E301
          hello
          which machine is the error code on as it doesn't say in the feed's.
          • WATTY
            • Oct 2014
            • 12
            Re: C-E301
            When C-E301 occur, and then C-E002 may occur after the machine rebooting or turning the main switch off and on.
            Symptom:
            When sending IPaddressFAX to multiple destinations by multi-address transmission, C-E301 may occur if the machine fails to send one of destinations, and then C-E002 may occur after the machine rebooting or turning the main switch off and on.
            Note)
            This bugfix is rolled out from C754 series
            Solution
            This problem has been fixed on the FW version GC9-F9 onwards.
            • emujo
              • Jun 2009
              • 3009
              Re: C-E301
              Yeah, tried this also, but since it wasn't enabled in admin mode prior to the fault, I can't save the logs to USB. Not sure if I can get them through PSWS. Emujo
              • emujo
                • Jun 2009
                • 3009
                Re: C-E301
                Originally posted by WATTY
                hello
                C554.
                • emujo
                  • Jun 2009
                  • 3009
                  Re: C-E301
                  Done, and no change. Emujo
                  • emujo
                    • Jun 2009
                    • 3009
                    Re: C-E301
                    Well, this is fixed, turned out to be a mixture of a poorly seated connector for the transport motor, and a bad MFP board. During the firmware update process both the MFP and Printer showed NG. Had to use the original MFP board to load the printer firmware, then the new MFP board to reload the MFP firmware. Applied the "cleansing tool" and system came up. Did have to do a complete init and re-setup entire MFP, but this seems to have done the trick. Additionally, when I re-attached the finisher for testing, the MFP started generating finisher ROM error codes. Check sum in the firmware screen was 0000. Wouldn't accept new firmware, so I had to replace the finisher main board along with all the other work. All told, about 6-8 hours to get through this. Emujo
                      • 23008
                      Re: C-E301
                      Don't you love KM? When you have a firmware related problem, it's a douzie, and it's never isolated to just one board. Like a virus it seems to infect the whole organism. Thanks for sharing. =^..^=
                      • MVPunisher
                        • 209
                        Re: C-E301
                        Wowsers. Good job.
                        • Makinbacon
                          • Aug 2014
                          • 32
                          Re: C-E301
                          11-6-14 KMBS just released a special firmware to resolve this error. If you have a KMBS login... Hope this helps someone.
                          "11/7/2014162.93 MBC224 C284 C364 A1610Y0-F000-GC8-72.exeRelease Notes: bizhub C224, C284, C364 Special Firmware Version GC8-72 Correction of C-E301, B003/B116"
                          • habik
                            • 2013
                            Re: C-E301
                            Thanks for the heads up Makinbacon.
                            Well done Emujo!
                            Sent from my iDon't believe in marketing device using Tapatalk
                            Firmwares HERE
