Bizhub-350 monochrome, printbutton flashing quickly amber.
  • Hansoon
    • Sep 2007
    • 3376
    Bizhub-350 monochrome, print button flashing quickly amber.
    Machine was working OK until one of my techs replaced rollers in port #2. from than on we had service code C-3751, message "Install Drumunit" and other weird behavior.
    What we did until now, not out of believe but out of dispair:
    New firmware, total reset, replaced PWB A, MFBS-board, Power unit.
    What we did not yet do:
    Use the POS as a boat anchor.
    What am I overlooking? Any ideas please?
    Hans
  • CompyTech
    Super Tech
    • Feb 2011
    • 706
    Re: Bizhub-350 monochrome, printbutton flashing quickly amber.
    Roll it off the dock into the dumpster...
    Did you try replacing the fuser too?
      • 23002
      Hans
      Ding, ding ding, ding, ding, ding! We have an answer! =^..^=
      • pepper38_cnd
        Field Service Manager
        • Aug 2005
        • 1075
        Flashing Amber usually means the machine was left in Service Mode 2, or corrupt firmware. But since you say this happened after servicing Tray 2 feed section, I would remove the bypass assembly and inspect the connectors for bent pins, damaged, pinched or broken wires.
        Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
        Now into Ip TV KODI Boxes
        • Hansoon
          • Sep 2007
          • 3376
          For sure its must be something like a pinched wire or disconnecting connector under power. That was the first thing I looked for but didn't found something. Than I installed the firmware and than I started changing boards. Still no solution. Since the machine has one million and is of an older generation I will scrap it. But I would buy a beer for anyone giving me the solution. Just for shits & giggles if you got what I mean.
          Hans
