Here's the scoop! Brand new C454e, J6 firmware. Reboots only when printing from internal controller and from print report function from control panel. It copies fine, prints internal service mode lists and gradations and internal test prints fine. Prints from attached fiery are fine as well. Have reseated memory, ssd, hdd, and anything else I could find. No change.. I have put in for a diagnostic mfpb for the machine as I can't think of anything else, have also did a total memory clear just to be safe..
Further to that, I disabled the hdd and instead of rebooting directly (it just says an internal error has occured, machine will reboot and error will be cleared) It throws an C FCF3 Code.. This: CFCF3 ASIC third sheet memory master access had Completer Abort.. Again this only occures during a print, not copy, not fiery. Not scan. (via print reports function thru control panel) . Service mode prints are fine.
The copy and doc feeder work fine as does the fiery and it's interface. No DSC boards in the device. So that leaves me with the MFPB board correct?
Any input would be appreciated!
Regards!
A.
Regards!
A.
