Bizhub 362 / NEC IT3640D - Toner / Developer ??? Toner smearing, not fusing.
  • QUALITY IMAGING
    • Mar 2007
    • 20
    [CQ] Bizhub 362 / NEC IT3640D - Toner / Developer ??? Toner smearing, not fusing.
    I took over some NEC IT-3640D machines and am new to them. I have 3 Machines doing the same thing. What am I missing???? I did Drum & Dev change when it asked for it. New drum unit (OEM), and new DV Bag (OEM). Running generic toner from ACM. Machine sare fine for 10k - 20k and then toner starts to smear off. You would think its bad DV, but this is too soon to be bad. Could it be Transfer roller? Do I need to replace DV unit? 1 machine has 118k, 1 has 131k, and 1 has 262k. Please help.
    Mike
  • JR2ALTA
    • Feb 2010
    • 2028
    Re: Bizhub 362 / NEC IT3640D - Toner / Developer ??? Toner smearing, not fusing.
    your garbage toner has a different melting temperature than OEM. so when the pre-mix of toner from the bag runs through and it starts adding your garbage the problem begins
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      Replace the drum and dv and dv unit and replace your toner with OEM at the same time.
      Sent from my Nexus 7 using Tapatalk
