Konica Minolta C652 Drum, Transfer Belt and Fuser Reset
  • mearmi
    • Oct 2010
    • 350
    [Misc] Konica Minolta C652 Drum, Transfer Belt and Fuser Reset
    Hi
    How to reset Konica Minolta C652 Drum, Transfer Belt and Fuser Unit?
    Thanks and Regards,
    Mearmi
  • Foxhound
    • Mar 2014
    • 33
    Re: Konica Minolta C652 Drum, Transfer Belt and Fuser Reset
    (2) New Release
    counter.
    1.
    Select the key as follows.
    [Counter]
    [Life] [New Release].
    2.
    Select a unit where New Release is made.
    3.
    Press the Start key and perform New Release
    From Service manual I hope this helps
    • habik
      • 2013
      T160mA fuse can be bought at Katun, and its easy to find them on ITB and Fuser.
      Sent from my iDon't believe in marketing device using Tapatalk
      Firmwares HERE
      • copier tech
        • 8200
        The C652 doesn't use a fuse system, the reset procudure was correctly posted above.
        It the c451 series that uses a fuse.
        • habik
          • 2013
          Nr tripping on vendor models! Ta
          Firmwares HERE
