kmbh c452 print yellow background on every printout p-22 error code appear
  • kizi57
    • Dec 2010
    • 69
    Please help as per subject
    in every printout i there is yellow solid background (see attachment below).
    also there is error code p-22
    Thanking you in advance
    IMG_2196 copy.pdf
    • 8132
    Re: kmbh c452 print yellow background on every printout p-22 error code appear
    What is your yellow IU life?
    • kizi57
      • Dec 2010
      • 69
      Life of yellow IU is almost 70%
        • 8132
        Start by cleaning the IDC sendors, run a gradation ajust, if still yellow background replace the yellow IU
        • cbp.patel
          • Aug 2013
          • 6
          drum charge unit problem. clean charge unit.
          • kizi57
            • Dec 2010
            • 69
            Thank you sir for your input, please let me know how i can find charge unit, do you mean laser?
            • B0265
              • Jan 2007
              • 718
              It might be the laser unit, we had a similar problem on a C451 recently.
              • WATTY
                • Oct 2014
                • 12
                Hello
                I have had this on a c451 and it turned out to be the laser unit, covered it yellow on the entire page.
                good luck
                • copyplus
                  • Jul 2009
                  • 100
                  Is it possible to interchange the IU from C451 to C452?
                  • minimerlin
                    • 851
                    I would go for the laser. I have had the same problem but with cyan background! Place a bit of paper over a part of the yellow laser window. If a white stripe shows on copies/prints then that confirms it as the laser.
                    Please do not PM me without asking first.
                    • copyplus
                      • Jul 2009
                      • 100
                      I am looking at buy a C452 which has a yellow background printing problem. The machine has only 56k copies on it. The owner demanding $600 for it. Is it worth buying that machine if 1) the laser unit is not working or the IU needs replacement. thanks
                      • Smyers
                        [ATTACH]27085[/ATTACH]
                        Yellow IU may not be seated securely or its bad
                        • Jamesb123321
                          • Nov 2019
                          • 1
                          ive had this before, i would change the yellow drum first if that fails look at HV board
                            • 8132
                            This was a post from the year 2014. I will assume the original poster has resolved the issue by now.
                            • Synaux
                              • Mar 2012
                              • 1224
                              Well... you never know
