bizhub (C280) List Output "USB save"
  • John Kaufmann
    • Sep 2013
    • 115
    The "List Output" section of the service menu (for Machine Management List, Adjustment List and Parameter List) has three output options: 1-sided print, 2-sided print, and "USB save". Selecting either of the print options outputs the print immediately, but selecting "USB save" does not seem to write to a USB stick in the service port. Unfortunately, the Service Manual does not address the USB output option at all. What is needed to make it work?
  • EarthKmTech
    Step aside, noob
    • May 2009
    • 2139
    Re: bizhub (C280) List Output "USB save"
    you dont need to put the stick in the service port, I use the port on the side near the panel all the time.
    The stick does have to be formatted correctly to work, and I always insert it before going into service mode and wait for it to be recognised first. Thats what I do and it always works for me.
    • John Kaufmann
      • Sep 2013
      • 115
      Thanks - I will give that a try.
      It's a 4GB stick formatted FAT32. That should be good, correct?
