The machine pop up this code during pre-drive and I found the fuser drive motor didn't rotate.
I rotate the fuser roller manually and the loading is normal and the wire connection is also normal.
Could it be the motor or the circuit board that attatch on the motor being failed?
If anyone has exprience this issue, please share your exprience.
Thank you!!
Thank you!!
