Re: Bizhub C451 printing problem
Let's say the transfer belt assembly is the culprit. Well only changing the belt if you can find one may not solve the issue. I would like to imagine that if the other colors print good the belt would not be an issue. It would probably be an issue related to 1st transfer for the black within the transfer belt assembly.
What you need to do is run the black halftone page and do a half stop test. Basically meaning you stop the machine part way thru the process and see if the pattern shows up on the drum. If so then replace the Black UI is what I would try first. If the image formation on the drum is good then look at the belt and see if the issue is there.
