Bizhub C451 printing problem
  • copyplus
    • Jul 2009
    • 100
    [Misc] Bizhub C451 printing problem
    My Bizhub C451 was working great since last week. I turned the machine off in the evening and next morning when I turned on it started printing with lot of toner on it and color was changed to black and white (see page 1) and then after making about 20 copies it still gave me lot of toner in the background but started giving me color. After printing about 40/50 copies the machine starting printing clear and crisp copies. The same thing happened the next morning. Now I do not turn off the machine and it is working fine. What is causing the machine to print like that when I turn it on in the morning? Any help will be appreciated. thanksScan1.PDF
  • Zackuth
    • Aug 2009
    • 448
    Re: Bizhub C451 printing problem
    The problem could be a firmware issue, a hard drive issue, or something wrong with the power/outlet the machine is plugged into. At least that is where I'd first start looking. You can shut down the copier and check the plug for signs of arcing, the plug prongs should be smooth, any rough or black spots would indicate arcing, if so call and electrician and have the plug fixed.
    If at first you don't succeed, redefine success
    • copyplus
      • Jul 2009
      • 100
      My machine runs fine if I don't turn it off. It gives me problem only if I turn if off in the evening and turn on next morning. That machine has been working fine since I installed it in May of this year.
      My all the imaging units on my Bizhub C451 and C203 are working fine. I just want to know if I want to just change the drums of the imaging units on these machines which drum will fit and which developer will be needed (from other bizhub models).
      • copier tech
        • 8174
        What is the environment like, does the temperature drop significantly over night, condensation could form inside the copier, on the drums & transfer belt, usually when the office heating starts up first thing in the morning.
        • tulintron
          • Jul 2014
          • 668
          Originally posted by copyplus
          My Bizhub C451 was working great since last week. I turned the machine off in the evening and next morning when I turned on it started printing with lot of toner on it and color was changed to black and white (see page 1) and then after making about 20 copies it still gave me lot of toner in the background but started giving me color. After printing about 40/50 copies the machine starting printing clear and crisp copies. The same thing happened the next morning. Now I do not turn off the machine and it is working fine. What is causing the machine to print like that when I turn it on in the morning? Any help will be appreciated. thanks[ATTACH=CONFIG]27175[/ATTACH]
          In my view, we have two problems !!!
          First - UI K C451 are problematic with bad contact. Other models already have UI K screwed.
          Two - The absence of other colors may be the clutch triggers the transfer of the belt. When it fails, so transfers black, but can produce the day
          all in trouble. Intermittent defect.
          I have helped.
          • Smyers
            Sounds like like drums were COLD. If temp drops very low where copier is located it will print black copies until drums actually warm up
            • copyplus
              • Jul 2009
              • 100
              You are right. I believe the problem occurs when the machine is cold and throughout the day it works fine. Usually, I turn the temperature down on my thermostat over the night. I will leave the heat on overnight and observe next day. thanks
              • copyplus
                • Jul 2009
                • 100
                Is it possible to use IU from Bizhub C451 to C452? thanks
                • habik
                  • 2013
                  On the back of the machine is a switch (heater) next to power plug. Turn it ON. And switch your machine only at the operating panel. Leave Main Power switch ON.
                  C451 IU and C 452 IU are different! Chip, design, the lot.
                  Sent from my iDon't believe in marketing device using Tapatalk
                  Firmwares HERE
                  • copyplus
                    • Jul 2009
                    • 100
                    I turned off the main switch. The switch on the back of the machine is on and I tried to turn on the machine from the panel switch but it does not turn on. I also tried to turn on and off the back switch.
                    Is there any other Bizhub machines IU compatible with C452? thanks
                    • copyplus
                      • Jul 2009
                      • 100
                      Sorry, I misunderstood. The main power switch needs to be on all the time but over night the panel switch should be turned off. thanks
                      • allan
                        RTFM!!
                        • 5462
                        1. I have swopped parts between the units before if i cant get stock C451 and C452. Check the transfer retraction on the belt.
                        Whatever
                        • copyplus
                          • Jul 2009
                          • 100
                          The machine's waste toner box was full and the machine did not give me any indication. I emptied the waste toner box and the machine is not leaving heavy toner on the prints. But now I have another problem. The print is not solid. please see the attachment and let me know what needs to be done. thankstest print.jpg
                          • copyplus
                            • Jul 2009
                            • 100
                            I did not receive any response yet. Will anyone please advise me what to do. thanks
                            • copyplus
                              • Jul 2009
                              • 100
                              I did not receive any reply yet. Is this too difficult problem? I need help, please thanks. test print.jpg
                              This is the printed sample of bizhub 451.
