51-4 code. replaced developer unit and developer and dev motor assly but no luck. did an L detect and it popped a 0005 code after calibration (referencing the developer or main pcb) any other ideas appreciaqted. I know i'm missing something here. Thanks t
Konica 7145
DarthAlbin
Check the ICPs on the "main" board (not the system board but the driver board. I've seen those blow causing motors to not function. Our guys keep a few on hand to solder in the field. -
if you've tried changing all of the obvious i recommend updating the firmware. i had the same problem, changed the dev and dev tank which made no difference. my colleague went in, updated the firmware and the machine has been ok for a few months nowComment
redime
Id try the easy stuff first like making sure the dv motor turns...Comment
