Bizhub c25
  • macuk
    • May 2009
    • 90
    Bizhub c25
    I have a customer with a low volume c25. Shortly after changing the black toner cartridge it came up with the message "Caution. not installed i-unit. check k.
    I have tried a new drum chip and cleaned and checked the connections with no sucess Has anyone had this? Attached is a pic of the message. Any help appreciated!
  • mo0651
    • 1054
    Re: Bizhub c25
    Check the contact springs on sensor. Have had bad Iu's.
    • allan
      RTFM!!
      • 5462
      Re: Bizhub c25
      We had a batch of bad after market chips that gives that massage. Got the good stuff and the problem was gone.
      Whatever
      • copier tech
        • 8172
        Re: Bizhub c25
        I'd start with a new genuine K image unit
        • EarthKmTech
          Step aside, noob
          • May 2009
          • 2139
          Re: Bizhub c25
          Cant be that low volume if they have already used up the original chipless out of box imaging units.
          Theres several issues relating to toner / iu detection on this model - but as your not using a genuine IU I shall go no further as that in itself is probably the issue.
