End of life firmware
  • rdj427
    • Aug 2025
    Hi
    Does anyone know where I can get hold of End Of Life Firmware for C253 and C280?
    Regards
    Rob
  • copier tech
    • 8200
    Re: End of life firmware
    I can supply this firmware for a small fee to cover my time to upload it etc.
    pm if interested
    • Don N.
      • Nov 2011
      • 409
      I have it, but you will need the firmware imaging toolkit to burn C253 series to a CF card. I think an old one from a DI2010 series will due. C280 series will go right onto a thumb drive but max size recognized is 2GB and it must be formatted FAT32.
      • allan
        RTFM!!
        • 5462
        Ok for C280 - remove cover behind waste box 3 screws. look on top of the drum and dev connectors for the open space where you can get a paper clip in. Short out pin 1 and 3 for the drums and 1 and 5 for the dev units. Insert screwdriver to close door switch for a short but not to short time. If no luck repeat until reset.
        Whatever
