C2257 Bizhub C754e
  • Guy Milner
    • Nov 2013
    • 61
    [Error Code] C2257 Bizhub C754e
    Hi,
    I have a C754e that's done 300k. C2257 error causing machine down. I visited yesterday and fully vacuumed out the waste toner from the cleaning section of the transfer belt as well as the nozzle out to the waste toner container. The machine reset and worked for the rest of the day. This morning, it has come back in for the same error.
    Any ideas?
    The transfer belt life on this model is 1.2million, so I don't really want to have to change it....unless there is no other option !
  • Max
    • Oct 2011
    • 554
    Re: C2257 Bizhub C754e
    Go in to test output mode and test the M38 motor. See if you can turn the cleaning station of the belt by hand, check gears. Possibly faulty M38 motor if the cleaning station is ok.
    • Guy Milner
      • Nov 2013
      • 61
      Have spoken to Konica Tech Support and they have had some issues with M38 motor, so I will order one for now. I will go and check the machine now and update.
        • 22999
        It might be informative to know if the transfer cleaning unit is clogged up again. =^..^=
        • Guy Milner
          • Nov 2013
          • 61
          I returned and stripped down and vacuumed the transfer unit more thoroughly. The M38 motor was sent to the customers in anticipation of another failure. As yet, a few weeks later, it is still ok.
          So for now, the motor hasn't been fitted.....
          • akd
            • Nov 2009
            • 11
            Guy did this problem go away?
            I ask because we are having a run on c2257 codes on the older c452 models. TBU cleaning unit is solid.
            • B0265
              • Jan 2007
              • 718
              Have seen this a few times, the cause was non-OEM toner.
              • Darw28
                • 14
                • akd
                  • Nov 2009
                  • 11
                  yes we use non OEM toner, have for 5 years on these machines, it has only just started.
