c224 freezed on konika minolta display
  • juve
    • Dec 2012
    • 86
    hello
    I have a konica minolta bh c224 with a problem.when switch it on,it remains freezed on the konica minolta display.have somebody else encountered this problem and can give me a helping hand please?
  • habik
    • 2013
    Re: c224 freezed on konika minolta display
    Try firmware update even if it is the latest, just re-flash it. System clear if it allows you to get to service mode, if not try new RAMs which might be the case. Disconnect HDD. See what happens.
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • juve
      • Dec 2012
      • 86
      ok,I will try with the firmware first.and than see what happens.I will let you know
      • allan
        RTFM!!
        • 5462
        Is it an E range machine?
        Whatever
        • juve
          • Dec 2012
          • 86
          no its not c224e ,it is c224.
          • Dawid
            You need to install latest special fw but I had the same problem. I had to replace vnram (SSD) but this is not so easy.
            • juve
              • Dec 2012
              • 86
              up till now we tried to put the latest firmware,but it is not getting it,it is staying on the display with black dot on the right corner and nothing happens,now we have to replace the rams,but this to be done tomorrow.the only doubt I have is that we didnt used 2gig usb(it is not common now),so maybe it didnt accepted the usb!!!!
              • habik
                • 2013
                For as long you have formatted the USB stick as FAT32 and have left the name of the USB stick blank (crucial) you should be fine with 2GB . No security features on USB stick though and copied files direct to the root of the stick!
                Firmwares HERE
                • copier tech
                  • 8200
                  Just to add this model is fussy about what type, brand & size of USB, it must be no larger than 2GB. Try updating on another working c224 first, if that works you know it should work on your faulty 224.
                  • Saghir377
                    • Feb 2013
                    • 47
                    hi hope you succeed in salutation of this problem. if not try to replace any other NVrom its only possible from this take out NVrom and try it any other machine try to rewrite firmware in other machine.
