Printing - Copying Problem with C350
  • ismail
    • Nov 2014
    • 34
    these are the problems now... the black imaging unit is brand new. i have problem with P-5 and P-21 but these are for Cyan. I have changed yellow iu chip. Any help? Original.pdf Print.pdf
    • 14497
    Re: Printing - Copying Problem with C350
    P-5 and P-21 have nothing directly to do with cyan. P-5 has to do with the front AIDC sensor. P-21 relates to an issue with a colour shift test pattern. So, you either have an AIDC sensor problem, or a transfer belt problem.
    Hope this helps
    • ismail
      • Nov 2014
      • 34
      Thanks for your quick reply. I will take out the transfer belt and clean it. i think it has a problem with cleaning it, but i will check it more carefully. Do you think that this bad print to black,caused by this problem?
      • darry1322
        • Oct 2010
        • 817
        Do the color units print similar output?
        If your problem is only with the black unit you may need to clean the LED array that writes onto your black drum. It can get filmy and produce a faint black image.
        • habik
          • 2013
          Do this procedure I wrote in this thread just a day ago!
          Next time do a thorough search through the forum!
          http://www.copytechnet.com/forums/ko...ack-color.html
          Sent from my iDon't believe in marketing device using Tapatalk
          Firmwares HERE
          • ismail
            • Nov 2014
            • 34
            I have this pattern for the colors
            • habik
              • 2013
              You need to check up the cyan IU as that is whats missing. Either no supply of toner or the Cyan drum/dev unit is no good. Unfortunately you wont find out whether the Print head is good until you change the Cyan IU. Good luck.
              Firmwares HERE
              • habik
                • 2013
                Try and give the cyan iu a good shake and turn the dev gear to give it a start rotation!
                Firmwares HERE
