C224e Firmware upgrade - flashdisk problem
  • lebo
    • Aug 2012
    • 88
    Hello, Bizhub C224e has well known problem with reading flashdisk FAT32 formatted in Windows during bootup.
    A few days ago I lost my only one formatted by MAC OSx to MS-DOS(FAT32).
    Right now I have no MAC in my close neighbourhood and I need to resolve this problem on Monday. None of my flashdisk formatted in GPART Linux Distro does not work as well.
    I am frustratted and helpless and I hate KonicaMinolta developers for this bug.
    Please help me. Please.
    Thank you.
  • copier tech
    • 8167
    Re: C224e Firmware upgrade - flashdisk problem
    If you use a 2gb you can simply format the USB drive in Windows!
    if you don't have one ask to use a customers Windows PC.
    • allan
      RTFM!!
      • 5462
      "c>Format X: FS:FAT32" From windows command? The machine dont like some manufacturers Kingston is at the top of that list. I am using verbatim 8GB drives and works on all the new Konica minolta machines. 2Gb is not enough space for the "fw select" function i have 5 diverent versions of firmware on one drive.
      Whatever
      • lebo
        • Aug 2012
        • 88
        Thank to all,
        I hunted out PC-MAC to resolve it.
        Bye.
        • mo0651
          • 1054
          I see you are a Mac nut!!! good to know. On a windows PC you go to My computer, right click on thumb drive, select format, select FAT 32 and let the computer do it.
          • wseyller
            • Sep 2012
            • 1129
            The drives I use for this series which are Fat32 of course I also use it for other unrelated stuff such as loading drivers and software on it temporarily. Sometimes for what ever reason it will stop working for firmware on the E series. If I do another quick format it will not help. If I do a full fat32 format it then works again. It just takes a while to do a full format depending on the size and speed of the drive.
