C224e J3003
  • JSC
    Gimp
    • Dec 2006
    • 618
    [Jamming] C224e J3003
    The gene pool could use a little chlorine.
  • habik
    • 2013
    Re: C224e J3003
    Check if transfer belt isn't stiffing up. Check the waste auger on the belt. The waste chute to waste box as well!
    Sent from my iDon't believe in marketing device using Tapatalk
    Firmwares HERE
    • JSC
      Gimp
      • Dec 2006
      • 618
      Re: C224e J3003
      Thanks habik. Done that and changed the belt as well..
        • 14763
        Re: C224e J3003
        Check the bushings in the registration assembly. They gum up and can slow things down. It is a bit of a pain to remove the assembly. It took about 1 1/2 hrs to remove, clean and re-install it for me.
        Hope this helps
        • habik
          • 2013
          Re: C224e J3003
          Hope this helps
          Wow we getting this issue on C203 series .. Never on the 224e series .. They are too young for that, or does your machine do a lot of clicks?
          I wonder if this gum up is caused by a certain paper.
          Firmwares HERE
          • JSC
            Gimp
            • Dec 2006
            • 618
            Re: C224e J3003
            Hope this helps
            I have swapped the reg unit assy completely from a showroom machine.
            • allan
              RTFM!!
              • 5462
              Re: C224e J3003
              Check is that door is ok, sounds like somthing could be warped or bent. Press agains it when operating.
              Only M1 conectors and Boards remain!
              Whatever
              • JSC
                Gimp
                • Dec 2006
                • 618
                Re: C224e J3003
                Hum, haven't thought of that. I will check on that tomorrow.
                thanks for that allan.
                • allan
                  RTFM!!
                  • 5462
                  Re: C224e J3003
                  Looks like a S@$% job to remove CL8 from the fuser drive.
                  Whatever
                    • 14763
                    Re: C224e J3003
                    I just had one last week with only 180000 on it with the bushings all gummed up. That's why I mentioned it.
                    • JSC
                      Gimp
                      • Dec 2006
                      • 618
                      Re: C224e J3003
                      its not quite as bad as it looks. I've done it twice now, once to strip and clean it, it was covered in fsr grease so when the call came back in I replaced it. It takes about an hour to strip and rebuild.
                      • JSC
                        Gimp
                        • Dec 2006
                        • 618
                        Re: C224e J3003
                        This one has only done 40k.
                        • JSC
                          Gimp
                          • Dec 2006
                          • 618
                          Re: C224e J3003
                          โ€‹fitted M1 yesterday, no bounce back yet.......
                          • allan
                            RTFM!!
                            • 5462
                            Re: C224e J3003
                            Hope all is well
                            Whatever
                              • 23008
                              Re: C224e J3003
                              I don't know if it will be any help ... but I had a bizhub 654e the other day that was giving J20-03 and J30-03 jams that would not clear. I found the registration switch PS38 sticking. If you bang the door it sometimes pops back until you try to pass another piece of paper. I must have disassembled the registration section 30 times before it stopped sticking. I honestly have no idea what was sticking or what I changed to make it work. The reg switch is underneath a paper dust collector.
                              And I'm a glutton for punishment. The flag was worn and the torsion spring deformed, so I've ordered new parts. Hopefully I can do a repeat performance. =^..^=
