bizhub c220
  • vijaysharma
    • Sep 2008
    • 61
    bizhub c220
    hi,
    when i'm trying to update the firmware of c220 the machine says invalid memory. Is anybody have solution
  • allan
    RTFM!!
    • 5462
    Re: bizhub c220
    On start-up? Change the flash drive?
    Whatever
    • copier tech
      • 8169
      Re: bizhub c220
      Format your USB stick, Fat 32 in Windows & only copy the .TAR file to the root
      • vijaysharma
        • Sep 2008
        • 61
        Re: bizhub c220
        I format USB stick and copy the firmware in A0EDFW.tar file but it only showing invalid memory
        • copier tech
          • 8169
          Re: bizhub c220
          Try another USB as said above
          • vijaysharma
            • Sep 2008
            • 61
            Re: bizhub c220
            I tried so many USB of different make but still not
            • copier tech
              • 8169
              Re: bizhub c220
              Try & update the firmware over pagescope
                • 14791
                Re: bizhub c220
                The thumb drive should be between 2 and 8gb (although I have used larger ones). The file has to be on the root of the drive, not in a separate folder. I find it works best if there isn't anything else on the thumb drive besides the firmware.
                Hope this helps.
                • mo0651
                  • 1054
                  Re: bizhub c220
                  Are you using the service port?
                  • allan
                    RTFM!!
                    • 5462
                    Re: bizhub c220
                    Mabe the problem is not with the USB but internal?
                    Whatever
                    • WildbillC
                      • Oct 2010
                      • 49
                      Re: bizhub c220
                      Try unchecking "quick format"
                      • vijaysharma
                        • Sep 2008
                        • 61
                        Re: bizhub c220
                        hi, everyone
                        i'm using service port, and the USB 2.0 stick is between 1GB to 4GB of different make.
                        firmware copied in root drive of USB, but again machine showing invalid memory.
                        • copier tech
                          • 8169
                          Re: bizhub c220
                          Have you tried updating the firmware via Pagescope?
                          • vijaysharma
                            • Sep 2008
                            • 61
                            Re: bizhub c220
                            I never tried to update the firmware via pagescope, can you provide me the procedure,,,,,thanks
                            • SmellsHot
                              Head Tech
                              • 512
                              Re: bizhub c220
                              TO see if the machine likes the USB stick just put it in the slot by the operation panel. I know you cant update the firmware this way, but the machine will either bring up the external memory screen or you will have a little red x through an icon on the display panel. If you have the red x than you need to find another stick...different manufacturer than what you've been trying. There really isn't any rhyme or reason to these things. I have best luck with corsair and Kingston....doesn't matter the size of them. I've had success with 2-128gb
                              Everyone has the right to be stupid. Some people just abuse this privelage more than others
