Scan to Email works for certain addresses only
+ More Options
Posts
  • ksantucci
    • Jun 2025
    Hi. I have a Bizhub C450 and we're having a strange issue with our scan-to-email.
    It will send perfectly to emails from our company's main address (blank@companyname.com works), but won't send to anything else. blank@sistercompany.com or blank@gmail.com errors out.
    Is there an admin setting to okay addresses? I'm going through all the settings but I'm not finding anything.
    Thanks.
    • 22997
    Re: Scan to Email works for certain addresses only
    If you're scanning via port 25, most likely the enduser's IT has limited the recipient destinations to xxx@companyname.com
    It's up to the local IT to change their policy if they want emails to leave the domain. =^..^=
    • KenB
      Geek Extraordinaire
      • Dec 2007
      • 3944
      Blackcat is right .
      The customer's IT needs to allow SMTP Relay on their email server.
      Not an MFP setting.
      • wseyller
        • Sep 2012
        • 1129
        Some company's purposely do this to only allow email sent to within the domain only for security reasons
          • 22997
          The idea here is that some employee could anonymously send out a contraversial document, with no way of tracking back who sent it. If the only doorway to the outside world is via a specific email, that person must tag the document with their sender's address. =^..^=
          • ksantucci
            I'm sorry for taking so long to respond. The New Years has put a big kink in operations. I've told the manager that handles the email settings (we're too small to have a proper IT dept) and we'll try that solution once this start of year crunch is past.
            Thanks for the help.
